5 members (TUTS 59, Rusted Nut, dgrinnan, UtahYork, 1 invisible), 342 guests, and 5 robots.
Topics128,162
Posts1,057,057
Members48,463
#1556618 08/28/2024 6:35 PM
Is there a support that connects the two headlight stands together. It would be in front of the radiator behind the grill. If so I guess one could be made easy enough.
1936 GMC T-14 restro-mod
FAST55 #1556683 08/29/2024 11:49 AM
This is the support that normally goes in front of the radiator in the grill shell. I think this is what you are asking about.
1936 GMC T-14 1/2-Ton Pickup
FAST55 #1556698 08/29/2024 3:09 PM
Yep, that's it. The one I found on e-bay was $250 plus shipping. I would think one could be made. Is this a 36 low cab only item? Going to be a bear to do with the grill assembled and mounted on the truck. That grill is a handful to assemble all the bars wink What would be the correct wording to locate one? Or a part number? Thanks for the reply.
FAST55 #1556769 08/30/2024 11:22 AM
The part number is 373568 and it is called a radiator shell reinforcement brace. It was used in both GMC and Chevrolet. And your right, it would be a job take the grill off to to install it. 1936 only.
FAST55 #1556787 08/30/2024 3:00 PM
Thanks for the reply Dunfire. Now I can start a search for it.
Moderated by  John Milliman
