7 members (NJC, baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna),
73
7
Mod | | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 35 Apprentice | | Apprentice Joined: Dec 2005 Posts: 35 | 1947 5 window big bolt flatbed. Picking up Wednesday. It is all there, and running, I havent had the chance to 'dig in' yet. Is there any safety issue with the older rims and tires or should I think about getting newer wheels and tires? (assuming the tires aren't rotten, worn or cracked) I don't see my truck ever going over 55mph, even if I put a sbc in it. I just don't like to drive a large truck very fast. Next question. What is the #1 upgrade people feel should be made first? Is there one area these old toads are lacking in? Paint and body will be the easy part for me, I'll be learning the mechanics as I go. I am pumped about this, I've been looking for about 3 years now and it looks like I've found my 4th child (or 2nd wife) -which will cost more? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey littlekings, Welcome to the Bolt! There is nothing wrong with the original style (split I'm guessing) rims. A lot will depend on what your going to do to the truck. You might have trouble finding somebody at your local car tire place to change the tires but most big truck places have the equipment and brains to do the job. As far as what to do first, make it safe. Unless it's a running driving truck right now, go through the entire brake system before you even think of taking it out on the road, this includes the hard lines. Being as your fairly new here I won't be to harsh but get some pictures so we can see it!  | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Here's what I've done and plan to do to the '54 6400 I picked up several weeks ago.
1. Clean fuel tank & replace sender unit 2. Flush fuel lines 3. New 1/0 battery cables 4. Bleed brakes 5. Rebuilt carb 6. Repair driveshaft noise (carrier bearing) 7. Rebuild brakes 8. Rewire 9. New tires
Items 1 - 4 were done in preparation for driving it home.
Item 5 was done the day after I got it home. I was showing the truck to a friend and had the hood up and started it so he could hear it run. A few minutes after it started, he started yelling to shut it off. The carb float had stuck and fuel was pouring out of the carb and over the quickly warming exhaust manifold.
I'd consider that a priority safety item. Most of the old truck I've owned or helped others with, have the same problem with the carb and tend to leak fuel. NAPA had the kit in stock for it.
The brakes are next and I intend to replace all of the steel lines and hoses as well as rebuild/replace the cylinders. The lines rust from the inside and can fail when you least expect it.
The wiring in these is originally insulated with a rubber compound that now crumbles whenever it is touched. As you work on the truck and move the wiring, it tends to expose more bare wire making for another bad situation.
The multipiece rims on the truck can be a safety hazard if they are heavily rusted or serviced by someone ignorant of whats involved in doing the job. A tire shop the does a good deal of truck or agricultural business should be able to take care of them for you.
Good luck and enjoy that new truck!
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | The first question should be, what is your intended use for the truck? Will it be a museum piece/occasional hayride wagon? Stay original, then. Will it be a working truck, doing the same jobs as a more current model? Then the biggest alteration you'll want to make (sooner or later) will be the differential ratio. If you start by replacing the entire rear axle with something from a later model then you'll have bigger, stronger brakes as well as a lower OTR engine speed, which will substantially help your fuel economy. Radial tires, absolutely, on a road truck. Tubeless tires will necessitate updated rims, but will run cooler. Bigger, better mirrors. Brighter lights, which might mean a 12V electrical system(it sounds like you might be doing that anyway). The engine is less important than any of those things, on a working truck. Here's a bad pic of what I thonk of as good mirrors. I can swing 'em out to see around a wide load. [img]http://thumb11.webshots.net/t/59/459/9/93/66/2193993660096215731StgIlR_th.jpg[/img] 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Brakes it the #1 thing. It doesn't matter if it goes, if it doesn't stop you're in for a bad day (& yes, I speak from expereince!). I did a full rebuild, all new lines, hoses, master cylender, & front slaves, and then I rebuilt the rear slaves and the parking brake. As was said before, if you have split rims take them to a truck or farm equipment shop, most common tire places flat out prohibit working on splits. I lucked out and the truck tire shop at a local chain still had a couple older guys that knew what to do with them, & I hear they had a lot of fun teaching the young guys how it was done back in the bad 'ol days. Wiring is a definate must do at some time, if you plan on making it 12V, may as well! As for what will cost more, a child, wife, or truck,... Well, it may cost you your wife, but otherwise they can be a pretty even split. If you have the time to look for parts & can get a good deal on them it's not too bad at all. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I would definately check the brakes for sure. I am lucky to be alive after taking the rear drum off my big bolt. Ewwwwww close one. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Welcome aboard, same suggestions as the rest. Brakes formost, then you can mess with the rest. I run the stock rims and tube tires, it seems fine to me. I dont like running much above 55mph either. Its a rough ride but Iam getting used to it. My wiring is falling apart too, still plenty to do. You'll be surprised how many thumbs up and smiles you'll get going down the road, good luck with yours. | | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | You mentioned that it was already running. If it's been running all along, you can probably disregard this. But, if you just got it running now, you may want to pull the gas tank and clean it--or at the very least, drain out all the old fuel, and replace it with fresh. You won't believe the havoc that can result from running a bunch of old varnish gas into your engine. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Brakes if you are building a museum piece you can do fine with a rebuild of the stock system if you are going to work the truck go to a duel master cylinder system. As for your rims the same thing but just because you have tube type dose not mean that you have widow makers. The widow maker wheels split in the middle and the wheel becomes two halves where as the good tube type wheels have a one or two piece ring that comes off one side of the wheel. | | |
