| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I've finally settled on a 250 (thanks Hotrod) for my 65 C10. It appears that the Rochester was the factory carb. But they were commonly replaced by a Carter YF back in the day, correct?
Also, is it hard to rebuild a Carter YF with a kit? i.e. Can it be done by a rank amateur? Do the kits have good clear instructions?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Instructions are OK- - - -but a short conversation with Jon (Carb King) would be much better. He usually recommends boiling the hard parts in a bath of Dawn dishwashing liquid and water, followed by a thorough hot water rinse and LOTS of high pressure air through every passageway in the carb. Solvents and "carb cleaner" sprays simply soften the crud- - - -massive volumes of air blows it away. Once the parts are surgically clean, follow the assembly instructions and adjustments to the letter. For instance, a Rochester Quadrajet has something like 22 adjustments to make during assembly, and a lot of them will have a cumulative effect on the accuracy of the next adjustment. A Rochester B or a Carter YF isn't quite that complicated, but the same principle applies- - - - -be careful, and OCD accurate! Jerry
| | | | | Joined: Oct 2021 Posts: 6,730 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,730 | If you have moderate mechanical skills and can read and follow instructions, the YF is simple to rebuild.
I hadn't rebuilt a carburetor since college and I rebuilt my YF a few years ago. It was one of the easiest repairs I've done on this truck. 8000+ miles later it's working fine.
1950 Chevrolet 3100 (Ol' Roy)
