0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1554226 08/01/2024 1:18 AM
I've finally settled on a 250 (thanks Hotrod) for my 65 C10. It appears that the Rochester was the factory carb. But they were commonly replaced by a Carter YF back in the day, correct?
Also, is it hard to rebuild a Carter YF with a kit? i.e. Can it be done by a rank amateur? Do the kits have good clear instructions?
1965 Chevy C10 Longbed Fleetside
Instructions are OK- - - -but a short conversation with Jon (Carb King) would be much better. He usually recommends boiling the hard parts in a bath of Dawn dishwashing liquid and water, followed by a thorough hot water rinse and LOTS of high pressure air through every passageway in the carb. Solvents and "carb cleaner" sprays simply soften the crud- - - -massive volumes of air blows it away. Once the parts are surgically clean, follow the assembly instructions and adjustments to the letter. For instance, a Rochester Quadrajet has something like 22 adjustments to make during assembly, and a lot of them will have a cumulative effect on the accuracy of the next adjustment. A Rochester B or a Carter YF isn't quite that complicated, but the same principle applies- - - - -be careful, and OCD accurate!
If you have moderate mechanical skills and can read and follow instructions, the YF is simple to rebuild.
I hadn't rebuilt a carburetor since college and I rebuilt my YF a few years ago. It was one of the easiest repairs I've done on this truck. 8000+ miles later it's working fine.
1950 Chevrolet 3100 (Ol' Roy)
10-4 thanks guys
