| | | Forums66 Topics128,122 Posts1,056,331 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok got double jointed and pulled my vacume wiper motor from my loadmaster last night, opened up the case, not too bad but sticking, got it all cleaned out and fresh, now... what lube do i use on the flapper????? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 48loadmasterguy,
I have heard petroleum jelly...Vaseline, works OK, but for some reason, I thought I remembered that a little brake fluid would do the trick too.
Probably anything that's compatible with the flapper material..I wonder if it's natural rubber. What does a "wiper motor lube" search turn up?
Stuart | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Arent those flappers leather? I also heard to use Vaseline. Marty | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Be careful using brake fluid on anything. My guess it that neatsfoot oil should work just fine.
From an article by Bob Adler in October 2004. Vintage Truck:"Make Components Last Longer"
"Vacuum wipers aren't known for Herculean torque, but you can grow fond of the hissing and flip-flop sounds vacuum motors make. Periodically, squirt some motor oil into the wiper-motor air intake (a pinhole near the valve-tripping mechanism, not the rubber hose going to the intake manifold) as the wipers are operating. This will help to seal the moving paddle to optimize power.
Tim | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey 48, I have used vaseline in the past on the leather and it worked fine. I would think any leather treatment should also work. You just need to get the leather supple again. By the way, got the emblems and the kid didn't pee, thanks! | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | The wiper is leather..When I rebuild wipers, I use Assembly Lube and the wipers work great with low vaccuum and at 0 deg. temp, snowing like crazy...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | I fergot, the gaskets are really thin and can't get the thin paper at flaps..found some in my old collection of papers..A guy I know who rebuilds vaccuum wipers says not to use silicone on the gasket, just a thin coat of grease..
Geoff
