3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#1552685 07/14/2024 6:47 PM
I
I Offline
I have a 50 Chevy and 216. I installed a new copper line to oil pressure gauge in new original style dash cluster. I tightened it well and can’t seem to keep it from leaking. It is 1/8” cooper with a brass fitting. It doesn’t look like a usual compression fitting with a ring. And the tube doesn’t fit through the fitting to flare it. Anyone have any suggestions or have a similar issue? I’d hate to go nylon or something.
Do you have a picture of the fitting? Ideally unhooked so we can see the pieces?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
If the fitting nut looks like THIS (what the stock nut should look like) you need to be sure the tube fits all the way thru the nut or it will leak. If you can't get the tube thru, then you need to buy a new nut.
7
7 Offline
klhansen is correct, if the tubing was not positioned all the way through the compression nut when you initially tightened it, you will need a new nut and start fresh. If the new tubing kit and nut is not the same style as the oil pressure gauge you'll have to determine what the gauge needs as far as fittings.
I
I Offline
Thanks to all for your information!
The nut is indeed the same as klhansen showed. Now that you explain it, it only gets a one and done use and was probably not all the way through the nut originally. I've ordered new nuts to give it a go again the right way. Again, thank you!
Yup! I’ve been there!
I had a new mechanical gauge that leaked behind the fitting. Must have been cracked brass threads.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I have been able to repair one of those by cutting off the steel line flush with the hex side of the fitting, then drill out the short length of steel line all the way through it and through the very end of the tapered end of the fitting. I then put the steel line back into the fitting with an 1/8" of the line protruding from the tapered end of the fitting and tightened it back into the gauge. No leaky, long time.
Moderated by  ndkid275, Phak1
