Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (68ironhead, Bill Hanlon, Waveski, Otto Skorzeny, Jon G, 2 invisible), 129 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
#155234 10/02/2007 8:16 PM
Does anyone know what a '54 8-speed automatic out of a ex-army GM 6x6 bolt up to besides the original gas 6-banger? Was it a GM bolt pattern? Are they any good? Any Korean Vets out there that drove these things? Thanks.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
#155235 10/02/2007 8:39 PM
I believe they were introduced after the Korean conflict, ended in 1953. I drove them in 1959 and 1960 and they held up well to abuse. I thought they were just a hydro with a low range and a high range transfer case, in other words a fourspeed with straight drive for the high range and a reduction gear for the low range. There was no split shifting. Don't know about the bolt pattern.
#155236 10/02/2007 8:51 PM
There is one of those that shows up every year at the ATHS show in Brooks.
The following are not dial-up friendly photos.
The card descibing the transmission is here: Twin Hydra Descriptoin
Pictures of that truck and the transmission are available in this folder: http://www.oldsub.com/images/2007/08/25_ATHS_Brooks/
You may have to poke around a little to find them.
#155237 10/02/2007 9:39 PM
Double Trouble, great name. grin Thanks for the dial-up OldSub. I'd like to repower my '51 GMC 640 and the automatic looked like a viable option if I could find a engine/trans application. Baldy your right on the date, I should have known I was born in '54. Thanks guys.
#155238 10/03/2007 1:34 AM
I looked at one of them in the junkyard the other day, it had a 270 in it. That deuce and half was cool but the automatic ruined it for me and the junk yard man LOL. He said yeah it's a good truck but has that stinkin' automatic in it.
#155239 10/03/2007 2:20 AM
It should have had a 302 in it IIRC. I never saw a military duece and a half of that era that was anything but an automatic while I was in the Army. The five ton Diamond/Reos had five speed manual transmissions.
#155240 10/03/2007 3:08 AM
Clutchheadstew, if you buy that army automatic, I hope your real name is Job because you will have to be a very patient driver. My recollection fo those things shift, shift, shift, shift, etc. Up, down, down again, then up again, then down, down, up, up, down, etc. Them was the most agravating things I ever came across in the truck world. I never understood why the Army wanted such a truck but I guess it was cheaper than teaching boys to doubleshift.
Jay
#155241 10/04/2007 3:22 PM
Wow, thanks guys. Looks like I'm running as fast as I can away from this truck. Thats what I expect from my Brothers and Sisters here at the Bolt, the honest truth!....Thanks, Rick
