3 members (60steve, rfs56trk, TexasA&M48Truck), 79 guests, and 0 robots.
Topics128,212
Posts1,057,463
Members48,471
Saw that these kits and you supposedly can get a little more speed out of these gears. Anyone done this and if so what's your thoughts on it? Plus how hard was it to swap?
Ross Taylor
Ross, More folks will be along soon to add their helpful info. In the meantime, check out this Tech Tip to get you going. wink
~ Dan
1951 Chevy 3 window 3100
ODSS Lawman
ODSS Lawman
Ross
In order to best answer your question, what are you considering installing these gears in? Having installed a few of these gears in my day I can say a 216 or 228 with these gears in hilly areas is not ideal. Its hard to believe 10 years have past since I wrote that Tech Tip, but the gears still zoom my truck along just great!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I’m currently in the middle of this very task on my 46 half ton. So far so good. I’ve just reached the reassembly phase of it.
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
It's a 54 Chevy truck with 235 motor.
Ross Taylor
Moderator, Electrical Bay
Hi Ross,
Not to butt in but a 235 and 3.55 rear gears generally is a good combination. I have 3.07 gears and mine works. As Sweet said hills can make me drop back to 4th, but usually I don't have to. 3.07/3.08 is the leanest edge of things I'd suggest, however. I'll explain a bit more...
If you had bought a 1960 Chevy El Camino with a 235 and a three speed with overdrive, you'd have gotten a 3.70 rear end. That's how they came from the factory. Overdrive would reduce the rear end gear by 30%, bringing it down to 2.59. It would have had smaller tires/wheels but with 3.55 you'll still be better off than that El Camino in overdrive. A big old station wagon would have given you the same rear end ratio. My final drive ratio in the pickup with a fifth gear of .86 and a rear of 3.07 is 2.64, so I'm right where the El Camino would have been...a little better, really. On the other hand if you had bought that El Camino with a 3 speed without overdrive, your rear end would have been...3.55. So in any case it will work for you. Good luck!
~ Jon
If your truck rear axle is a 54 it will have a 390 rear .Imformation I have heard is the 54 has a different carrier and requires a older carrier for the gears.My 54 has a older rear axle and is a Canadian model which has more alterations to make it work .Mine is still in the works
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
