| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 25 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 25 | Saw that these kits and you supposedly can get a little more speed out of these gears. Anyone done this and if so what's your thoughts on it? Plus how hard was it to swap?
Ross Taylor
| | | | | Joined: Sep 2009 Posts: 6,056 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,056 | Ross, More folks will be along soon to add their helpful info. In the meantime, check out this Tech Tip to get you going.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Ross
In order to best answer your question, what are you considering installing these gears in? Having installed a few of these gears in my day I can say a 216 or 228 with these gears in hilly areas is not ideal. Its hard to believe 10 years have past since I wrote that Tech Tip, but the gears still zoom my truck along just great!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2023 Posts: 120 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 120 | I’m currently in the middle of this very task on my 46 half ton. So far so good. I’ve just reached the reassembly phase of it.
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
| | | | | Joined: Jun 2022 Posts: 25 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 25 | It's a 54 Chevy truck with 235 motor.
Ross Taylor
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Hi Ross, Not to butt in but a 235 and 3.55 rear gears generally is a good combination. I have 3.07 gears and mine works. As Sweet said hills can make me drop back to 4th, but usually I don't have to. 3.07/3.08 is the leanest edge of things I'd suggest, however. I'll explain a bit more...
If you had bought a 1960 Chevy El Camino with a 235 and a three speed with overdrive, you'd have gotten a 3.70 rear end. That's how they came from the factory. Overdrive would reduce the rear end gear by 30%, bringing it down to 2.59. It would have had smaller tires/wheels but with 3.55 you'll still be better off than that El Camino in overdrive. A big old station wagon would have given you the same rear end ratio. My final drive ratio in the pickup with a fifth gear of .86 and a rear of 3.07 is 2.64, so I'm right where the El Camino would have been...a little better, really. On the other hand if you had bought that El Camino with a 3 speed without overdrive, your rear end would have been...3.55. So in any case it will work for you. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | If your truck rear axle is a 54 it will have a 390 rear .Imformation I have heard is the 54 has a different carrier and requires a older carrier for the gears.My 54 has a older rear axle and is a Canadian model which has more alterations to make it work .Mine is still in the works | | |
