0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
I was changing the mechanical fuel pump on my 1964 bus "Bessy" and I had trouble getting the sliding rod to stay up so I could get the pump arm to go back in. Someone suggested a hacksaw blade because they bend easy. I figured I would share this in case anybody else was having the same issue or will have.
Thank you all
Last edited by Gdads51; 06/17/2024 7:44 PM. Reason: edit title and move to correct on-topic forum
1968 Chevy c10
"Adding to the Herd"
Follow in the DITY Gallery
1964 Chevy Blue Bird Bus
"Bessy"
Follow in the Big Bolts
squatchie86, I have added a bit to your title to move the post into the correct on-topic forum The Engine Shop for folks to see and use as it may help them. Thanks for sharing! wink
~ Dan
1951 Chevy 3 window 3100
Given that Bessie had a rod activation there fuel pump, I'm guessing that she doesn't have a six cylinder engine.
Some (all?) Chevy small block V8 engines had a short bolt "around the corner" on the front of the block from the fuel pump pushrod. When you removed the short bolt you would find that the bolt hole went all the way to the fuel pump pushrod. All you needed to do was the thread a longer bolt into the hole and lightly snug it up against the pushrod to get the pushrod to stay in place. Worked best when the pushrod was in the "all the way up" position. At least that is how it worked on my wife's '72 307 Chevy engine.
7
7 Offline
Bill Hanlon is correct, all Chevy V8's have a push rod and all the small blocks have the bolt hole into the push rod cavity. I can't remember if the big block's have the bolt hole, it's been several years since I've owned a 396 and 454.
Not all small block V8 have the hole threaded the last bit, need to grind a bolt to a smaller diameter. Don't tighten the bolt past finger tight, have seen pump Pushrod bent in block by Mongo, it can be a bear to get out of the block.I had a dude working for me that did that, rod hung up and only give small pump action.
BC
1960 C60 pasture art
