| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | Hi all,
I'm working on my 1950 4400, and would like to rebuild my hydraulic pump. It works fine, but leaks like a seive. I checked Jim Carter's classic trucks, and they don't have such a kit listed,,, at least not that I could find.
Any ideas? Thanks,
Jon
Jon
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jon,
I would guess that your leaking hydraulic pump wasn't something Chevrolet manufactured or installed on your truck. You would need to go to the manufacturer of the pump itself for parts.
Many times seals, o-rings, quad rings and other items can be obtained from a bearing supply house by merely ID'ing the part, or taking the part in for them to measure.
Scratch around and see if you can find the manufacturer and maybe a model or part number.
Is this pump for a dump bed?
Stuart | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'd guess in the St. Louis area there would be some type of pump repair shop that could make the parts you might need. I'd suggest you stop at a local firehouse and ask where they get their hydralic pumps repaired. Fire departments have lots of hydralic tools. | | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | Yes, the pump is for the dump bed. I'll have to de-crustify it and see if I can get a mfg name off it. Thanks for the tip!
Jon
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Send me a photo of the pump and perhaps I can identify it. Also there should be a brand name on the subframe. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I went to a local truck supply/repair shop and got alot of help. If you goto rural area shops it's best as they see alot of off the wall stuff on farm vehicles. Hydraulic shops that work on farm equipment are good places to check as well. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
