4 members (Ponchogl, TUTS 59, Otto Skorzeny, Hotrod Lincoln), 128 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
Hi all,
I'm working on my 1950 4400, and would like to rebuild my hydraulic pump. It works fine, but leaks like a seive. I checked Jim Carter's classic trucks, and they don't have such a kit listed,,, at least not that I could find.
Any ideas? Thanks,
Jon
Jon
Jon,
I would guess that your leaking hydraulic pump wasn't something Chevrolet manufactured or installed on your truck. You would need to go to the manufacturer of the pump itself for parts.
Many times seals, o-rings, quad rings and other items can be obtained from a bearing supply house by merely ID'ing the part, or taking the part in for them to measure.
Scratch around and see if you can find the manufacturer and maybe a model or part number.
Is this pump for a dump bed?
Stuart
V
V Offline
I'd guess in the St. Louis area there would be some type of pump repair shop that could make the parts you might need. I'd suggest you stop at a local firehouse and ask where they get their hydralic pumps repaired. Fire departments have lots of hydralic tools.
Yes, the pump is for the dump bed. I'll have to de-crustify it and see if I can get a mfg name off it. Thanks for the tip!
Jon
Send me a photo of the pump and perhaps I can identify it. Also there should be a brand name on the subframe.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I went to a local truck supply/repair shop and got alot of help. If you goto rural area shops it's best as they see alot of off the wall stuff on farm vehicles.
Hydraulic shops that work on farm equipment are good places to check as well.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
