4 members (Ricks Big Dump, Donf, Peggy M, 1 invisible), 148 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#1548269 05/30/2024 3:10 PM
Is there any difference in length for the 2 parking brake cables that run from the center pivot rod to both drums? I found a few but they say 1951-1954 but I have a 50..thank you
According to the 1929-57 Chevy Master Parts and Accessories Catalog, 1947 2nd series -1950 1/2 tons used GM# 3686522 with an overall length of 40-3/4". The 1951-55 1st series used GM# 3694170 with an overall length of 40-7/8". Jim Carter offers MEB456 to fit 1948-55 1/2 tons. His description does say some minor modifications may be necessary. The Filling Station offers FS-392 for 1947-55 1/2 tons. Their description does indicate there is an added part RW-1 that is required on each cable to adapt them to your 1950 1/2 ton parking brake actuators. Hope this is helpful. wink
~ Dan
1951 Chevy 3 window 3100
1/8th of an inch difference eh? thanks for the info..I was looking at ebay who had a few at a cheaper price which is why I was wondering.
Huck brakes on 47-5? Then Bendix brakes. Might be the difference on cable ends.
1947 3600 Chevy
Seems you have to buy the ends separately or reuse the old ends if I am correct.
AD Addict & Tinkerer
Be very careful buying the cable. Some of the cables are not manufactured correctly. The difference is not at the brake end but the bracket that is riveted to the frame. I ran into this issue with my ‘52 and I don’t believe this bracket on the ‘50 is any different. Here is a thread on this issue. [LINK]
Phil
Project Journals
Stovebolt Gallery Forum
I called LMC..they do not have anything for the 50
