| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | Is there any difference in length for the 2 parking brake cables that run from the center pivot rod to both drums? I found a few but they say 1951-1954 but I have a 50..thank you | | | | | Joined: Sep 2009 Posts: 5,844 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,844 | According to the 1929-57 Chevy Master Parts and Accessories Catalog, 1947 2nd series -1950 1/2 tons used GM# 3686522 with an overall length of 40-3/4". The 1951-55 1st series used GM# 3694170 with an overall length of 40-7/8". Jim Carter offers MEB456 to fit 1948-55 1/2 tons. His description does say some minor modifications may be necessary. The Filling Station offers FS-392 for 1947-55 1/2 tons. Their description does indicate there is an added part RW-1 that is required on each cable to adapt them to your 1950 1/2 ton parking brake actuators. Hope this is helpful.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | 1/8th of an inch difference eh? thanks for the info..I was looking at ebay who had a few at a cheaper price which is why I was wondering. | | | | | Joined: Dec 2020 Posts: 281 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 281 | Huck brakes on 47-5? Then Bendix brakes. Might be the difference on cable ends.
1947 3600 Chevy
| | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | Seems you have to buy the ends separately or reuse the old ends if I am correct. | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Be very careful buying the cable. Some of the cables are not manufactured correctly. The difference is not at the brake end but the bracket that is riveted to the frame. I ran into this issue with my ‘52 and I don’t believe this bracket on the ‘50 is any different. Here is a thread on this issue. [LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | I called LMC..they do not have anything for the 50 | | |
