| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | When sitting at a traffic light, is it better to leave the vehicle in neutral with one foot on the brake, or leave the vehicle in first gear with one foot on the brake and the other foot on the clutch?
I guess the real question would be does the truck and /or it's components know the difference or care?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | I've been taught that foot on clutch makes the throw out bearing work. So if I know it's a long light I will put it in neutral and hold the brake Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | That's typically what I do. This morning while driving oOl' Roy to work and sitting at various lights, I started pondering that question.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Yes, the TO bearing spins anytime the clutch pedal is depressed. That also puts a load on the back end of the crankshaft main bearing with the thrust flange on it. Neutral and brakes applied at a long stoplight is a really good idea. Jerry
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Something I’ve been wondering for quite some time, but as soon as I consider going into neutral, the light turns green. Argh!
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Something I’ve been wondering for quite some time, but as soon as I consider going into neutral, the light turns green. Argh! Your driving a truck older than most of the drivers behind you (some of them combined together are not old enough) NO one is expecting you to light it off the line when the street tree goes green  . sling it in neutral  | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | And, I’d much rather install new brakes than I would a new clutch ðŸ˜
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Put it on neutral, wait out the red light. I’ve been watching for the intersecting light to turn yellow since I was a teen; thinking drag racing thoughts. Modern traffic lights are harder to view from the side, but I still watch for that yellow ; gets me off the line in a timely fashion. | | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | Or keep your eye on the pedestrian countdown clocks.
As far as taking off the from the line, several times I've had the person behind me slam on his or her brakes to keep from rear-ending me as I shifted from granny gear to 2nd. These tailgating retards around here have no clue how 75 year old, 3 speed transmissions work.
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Otto, I usually always start in 2nd gear for that exact purpose. . Unless on a good hill. Do you always start in 1st? Just wondering. Todd
1950 Chevy 3100
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | Yes, generally all the time. Starting off in 2nd doesn't satisfy my OCD.
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Awww. OK.. Makes sense Sir!
1950 Chevy 3100
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | Aside from decreasing the risk of being rear-ended, is there any advantage to starting off in second?
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Otto, for me: on FLAT ground starts, 1st gear with the stock 4-11 rear gears is a waste of time (Too low), Unless on a hill. Then it makes it simple shifting (For me) up and down (2nd & 3rd). I hardly ever use 1st gear. Maybe just me. Todd
1950 Chevy 3100
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Otto, are you driving a SM-420 4-speed or a standard 3-speed? SM-420 is normally driven starting in second gear unless loaded or on a very steep hill where the 3-speed always gets started in first gear to reduce clutch slip. Mike B  | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | His post said it was a 3 speed, but he also referred to first gear as granny gear. I've always heard that term used regarding a 4 speed.
I myself would always start a 3 speed in first, and a 4 speed in second, unless the truck was loaded. | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | With all of the manual tranny's I've driven, I almost always slide it into neutral just before coming to a stop if I anticipate having to wait for a light, and if I'm not trying to accelerate quickly I will upshift without the clutch. That won't work with my Harley 'cuz it has to be in 1st before you can find neutral.
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | Otto, are you driving a SM-420 4-speed or a standard 3-speed? SM-420 is normally driven starting in second gear unless loaded or on a very steep hill where the 3-speed always gets started in first gear to reduce clutch slip. Mike B  It's a three on the tree. I always thought low 1st gear was granny gear.
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Or keep your eye on the pedestrian countdown clocks.
As far as taking off the from the line, several times I've had the person behind me slam on his or her brakes to keep from rear-ending me as I shifted from granny gear to 2nd. These tailgating retards around here have no clue how 75 year old, 3 speed transmissions work. Point of order–- Granny gear in a 3 speed? My morning coffee session is now unsettled.
| | | | | Joined: Sep 2009 Posts: 5,902 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,902 | Folks, this has been an interesting conversation with a good topic. The question has pretty much been answered on what may be best operation for the life a trucks engine/driveline pieces while sitting at a stoplight and waiting to give it some go juice. Whatever way you all chose to operate your truck, do what works for you, but we're veering off into turning this into mostly chit-chat about the terminology used. Time to move on to another subject please and thanks.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
