| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 21 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 21 | The only time my '54 235 gives me problems is coming up the mountain I live on.
To be fair, big trucks/log haulers could be passed by a man riding backwards on a unicycle.
My question is, could it be float level? | | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | Try checking the resistance of the spark plug wires. They should have a maximum of 1,000 ohms per inch. It sounds like you have spark plugs and/or wires breaking down and missing under load. Jerry
| | | | | Joined: Nov 2016 Posts: 21 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 21 | Jerry,
I have gone through multiple sets of plug wires. It seems more like a carb issue to me.
Also seems to be more pronounced when it's warmer out. Valves?
It does seem to be relative to load.
| | | | | Joined: Aug 2018 Posts: 34 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 34 | | | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | Come on over to Townsend next weekend, and your truck can be the guest of honor at a troubleshooting clinic! Compression test, primary ignition circuit resistance test, distributor advance check, and maybe even a cylinder leakdown test. Like Sun Electric Company's slogan used to be- - - - -"We test, not guess!" Jerry
| | | | | Joined: Aug 2023 Posts: 5 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 5 | Put a fuel pressure gage on your fuel pump and see what it's reading. | | |
