0 members (), 194 guests, and 4 robots.
Topics128,187
Posts1,057,313
Members48,468
The only time my '54 235 gives me problems is coming up the mountain I live on.
To be fair, big trucks/log haulers could be passed by a man riding backwards on a unicycle.
My question is, could it be float level?
Try checking the resistance of the spark plug wires. They should have a maximum of 1,000 ohms per inch. It sounds like you have spark plugs and/or wires breaking down and missing under load.
Jerry,
I have gone through multiple sets of plug wires. It seems more like a carb issue to me.
Also seems to be more pronounced when it's warmer out. Valves?
It does seem to be relative to load.
Air/fuel mixture/timing
'48 Panel
Come on over to Townsend next weekend, and your truck can be the guest of honor at a troubleshooting clinic! Compression test, primary ignition circuit resistance test, distributor advance check, and maybe even a cylinder leakdown test. Like Sun Electric Company's slogan used to be- - - - -"We test, not guess!"
Put a fuel pressure gage on your fuel pump and see what it's reading.
