4 members (Otto Skorzeny, lumbersawyer, DadsFirstPickup, Hotrod Lincoln), 95 guests, and 3 robots.
Topics128,089
Posts1,056,367
Members48,442
Had the 37 out for the first time this year and it seemed like the cab shrunk,I know I need to loose some weight and will be doing some modifications so I can fit it it and put those in the appropriate sections when it happens. This got me to thinking about passing it down to a younger and thinner member of the family but would happen in a few years as I still need to find a truck I can fit in better.
Crusing in the Passing Lane
I raised the seat on one of my trucks, helped with space.
Ed
Ed,
I think it sounds like Jeff needs to lower his seat or install shorter/softer seat springs. This happens to so many of us as we get up there. Thus why I walk 6-7 miles a day. It keeps my truck happy
Craig
I think raising the seat would increase leg room/distance to pedals, but lowering seat, or installing a tilt steering column, would gain belly room.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Jeff, A peek at your interior picture (copied and added below for ease of access) from your Gallery Page shows just how little extra room there is in your 1937 Truck. If you do make changes, maybe consider something that may be more temporary than permanent. Or at the least, hang on to what you take out to change so it might be easily returned to the current condition. wink
~ Dan
1951 Chevy 3 window 3100
I have some changes in mind.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Jeff, Perhaps your conversation may better fit into the Interiors forum??? I've moved it to that forum for further discussion. wink
~ Dan
Does the truck in question have the gas tank inside the cab? I've often wondered why more guys don't relocate it, simply because these trucks were designed when guys were 5'6" on average. That extra 3-4" of room might make a big difference.
AD Addict & Tinkerer
The gas tank in my ‘52 is behind the seat. When the seat is back as far as it can go, the seat frame bumpers are touching the back of the cab. So even if I removed the tank, it wouldn’t buy me any room.
I’ve heard that an upholsterer can tie the springs back a bit to gain some room. That is what I’m going to try when I get to that point. I’m not sure if the ‘37 is the same way but it may be something to consider.
Phil
Project Journals
Stovebolt Gallery Forum
Moderated by  ndkid275, Phak1
