0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | Anyone familiar with a 250 Chevy motor? Did it come with a rochester carburetor 1 barrel, if so does anyone know the actual carburetor part number? Thanks Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | It was indeed a Rochester 1bbl but fortunately it was NOT a Rochester B or BC model. As I recall it could have been manual choke or auto choke. I also think it was the Rochester R-1 and there would have been an additional number for man/auto choke. I've seen some of these with Carter carburetors on them and one I had for a brief while had a Carter but I can't remember...want to say 4339 was the number? It was man choke.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2011 Posts: 1,454 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,454 | It would have come with a Rochester Mono-Jet. As for # I don't have that info.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2019 Posts: 77 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 77 | My 69 Nova L 6 , 250ci engine ; YES , it came with a "Rochester Mono-Jet carb" = 1 bbl . Look here (I just "searched Mono-jet carb" : https://www.ebay.com/itm/1759917897...p;campaignid=20856436953&mkgroupid=1I'm now using the Holley # 8007 , 4bbl , 390 cfm carb & OFFY intake . My car runs - - really good (using this set-up) ; still using my L 6 stock exhaust (here in Arizona) . . so,I still have stock "carb heat" . jim | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | That Rochester Monojet was sort of like a Dyson vacuum cleaner- - - -it "inhales vigorously"! I'd suggest using a Carter YF calibrated for a 258 cubic inch AMC/Jeep engine. It should bolt onto the original intake manifold, but you might have to do a little tweaking to get the throttle linkage working properly. Jerry
