2 members (Peggy M, Simso), 291 guests, and 9 robots.
Topics128,077
Posts1,056,034
Members48,433
#1544922 04/24/2024 2:49 PM
Anyone familiar with a 250 Chevy motor? Did it come with a rochester carburetor 1 barrel, if so does anyone know the actual carburetor part number?
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Moderator, Electrical Bay
It was indeed a Rochester 1bbl but fortunately it was NOT a Rochester B or BC model. As I recall it could have been manual choke or auto choke. I also think it was the Rochester R-1 and there would have been an additional number for man/auto choke. I've seen some of these with Carter carburetors on them and one I had for a brief while had a Carter but I can't remember...want to say 4339 was the number? It was man choke.
~ Jon
It would have come with a Rochester Mono-Jet.
As for # I don't have that info.
BC
1960 C60 pasture art
My 69 Nova L 6 , 250ci engine ; YES , it came with a "Rochester Mono-Jet carb" = 1 bbl .
Look here (I just "searched Mono-jet carb" :
https://www.ebay.com/itm/1759917897...p;campaignid=20856436953&mkgroupid=1
I'm now using the Holley # 8007 , 4bbl , 390 cfm carb & OFFY intake . My car runs - - really good (using this set-up) ; still using my L 6 stock exhaust (here in Arizona) . . so,I still have stock "carb heat" .
jim
That Rochester Monojet was sort of like a Dyson vacuum cleaner- - - -it "inhales vigorously"! I'd suggest using a Carter YF calibrated for a 258 cubic inch AMC/Jeep engine. It should bolt onto the original intake manifold, but you might have to do a little tweaking to get the throttle linkage working properly.
