6 members (moparguy, GMCJammer51, TUTS 59, jmoore, 66flea, Ponchogl), 117 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
I've got stomp-start on my 235. I'm fixing replacing the starter with a new gear reduction starter. Did it in my CJ5 and it's amazing, it starts faster than any of my more modern vehicles. Also being honest, I find of hate working on the truck and needing to either run into the cab to start it or yank the spring and reach down to starter it. I'd much prefer to convenience of jumping my solenoid like I can on every other older vehicle I own. But I do love the character and uniqueness of the stomp-start though and was thinking that it'd be great if there was some sort of electric switch that I could mount in the floor to trigger my starter solenoid. Anyone know of something that'd work for this? I that about maybe modifying a hi-beam switch to just be a momentary switch like what you'd want for a starter but I'd rather not go through that trouble if I could find an alternative.
-- Ian
'55 2-ton stakebed
You could do something like this: https://www.mcmaster.com/product/8382K31
It is a metal body momentary switch. Being IP66 rated, it should be fine in an automotive environment.
It is rated for 2.5A@24VDC, so you might need a relay (or a larger switch of the same concept) for the solenoid. I am not sure offhand how much current those solenoids draw.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
There are plenty of automotive duty foot switches on the market for what you are trying to do. Cole Hersee Starter Switch
Could you post a link for the gear reduction stovebolt starter?
BC
1960 C60 pasture art
Sir Searchalot
Sir Searchalot
We have had this question and answers. Try a search. As said, lots of "big" momentary push buttons available to design with. The one Mark linked is the type you want. Some folks have incorporated the original pedal and boot I think.
DR405C
9N11450A
I've seen a 3/4" pipe cap attached to the push button on a similar switch with set screws, with an original foot start pedal adapted to the cap. Then use a rubber accordion bellows from a rack & pinion steering tie rod to hide the switch and pipe cap from view. It looks very similar to the original foot start setup.
I have a stomp "switch" in the garage waiting for my 302 engine, which will have a 12v solenoid starter. The switch is from some tractor and it has a rubber "stomper" that I got from one of the usual old truck parts suppliers. Had to drill out the rubber part to match the size of the cap on the switch. A little black paint and it will look enough like a stock stomper that 90% of people who know what a stomp starter is would think it is original.
I’ve got the same setup. Got mine from a tractor supply. Now have to wire into park/neutral switch on shifter.😁
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Sure, here you go https://vintageautogarage.com/1955-...er-starter-w-168-teeth-flywheels-3599gr/
-- Ian
'55 2-ton stakebed
O Online: Content
$200 more than the standard starter to sound like a Highland Park Hummingbird? What's the point?
A standard 6v starter turns over the engine as fast as any modern car. It doesn't really have to spin much though since the points ignite instantly.
1950 Chevrolet 3100 (Ol' Roy)
Sir Searchalot
Sir Searchalot
Ian, it's good to acknowledge the responding posters and advise when your question is answered, to end the discussion if you are satisfied. If not, ask more.
Where's your source on starters? I'd love to find a starter that's only $80, cheapest I've found is $220, and at that point, might as well just get the GR starter for the extra $40.
-- Ian
'55 2-ton stakebed
Not sure why I hadn't thought to just use a push start, from a tractor like you have there. That looks like the starter switch of a 2/8/9N Ford. I think I'll do the same, thanks.
-- Ian
'55 2-ton stakebed
O Online: Content
What is the point of this switch? Is it simply to eliminate the mechanical spring and lever system?
In my case it is to make the interior of the truck look like the stomp starter mechanics are still in place when you have a solenoid equipped starter. The switch connects between 12v "hot when the key is on" to the S terminal on the starter solenoid. That way if you stomp it when the key is off, it won't make the "in gear" truck jump. A little safer than the original setup.
O Online: Content
But it eliminates the spring and lever?
Yes
Like Bill said, it replaces the manual stomp-start floor pedal that actuates the bendix with an electric switch that activates the solenoid, while having the same general appearance of the stomp-start pedal. In my case, my truck is no where near useable but I regularly find myself needing to start the truck while working on it. Every other vehicle I own, I just leave a push button wired to the solenoid and have an easy way to start it. With this truck I have to drop what I'm doing and go get into the cab. Just a three minute annoyance I'd like to eliminate.
It's little things like this that add up to a truck that I hate to work on. But I do like the character, history, and uniqueness of the stomp-start pedal and would like to keep some homage to it around.
-- Ian
'55 2-ton stakebed
K Online: Content
Check out barnfind49 in the project journal. He has a stomp starter like what you are looking at installing .There is a video to see how it works.
Last edited by Peggy M; 04/23/2024 10:46 PM. Reason: Barnfind PJ hotlink. (Good call Kev)
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
