1 members (KEVINSKI),
79
Mod | | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 340 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 340 | So I have a '36 T-14 and it came with some sort of aftermarket bed? like a service bed. Must weigh 4 or 5 hundred lbs. I have a bed off of a '46 pickup, do you guys think I can use it on my '36? I think it's about 2" wider than an original would be. The bed is in great shape and won't need a lot of work before paint.
1936 GMC T-14 restro-mod
| | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Fast -- Your tape measure is your best friend in this case and can answer your question better than most of us could.  When measuring, be sure the get all the details. Some *fitting* may require effort than just the regular length, width, depth. Now, how about those holes?  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2012 Posts: 340 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 340 | I have it setting on the frame, it's a little short, about 3''. I'm not sure how far from the back of the cab it should be, I'm thinking 1 1/2" max from cab. My only concern will be if the fenders are going to fit. I will have to weld up the fender holes in the bed sides and redrill them in the proper spot. I will have to put the running boards on and see. Will keep my fingers crossed. I can always bob the rear frame rails off a little if need be.
| | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Fast55, do any of these PDFs that dunfire sent back in 2022 help with what you are looking for?
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Oct 2012 Posts: 340 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 340 | Those look like they are for the cab mounts, which I have already done. I was just wondering about the difference in the bed width and the rear fenders fitting. I don't know how much adjustment is in the running boards, moving them away from the frame to make them wider. I guess I will have to mock them up and see what happens, hopefully I can make it work without to much work or it looking odd.
