5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
#1544321 04/17/2024 6:57 PM
8
nothing beats a try but a failure
8 Offline
Has anyone purchased Jim Carter's CB-126 and CB-124, lower cab windlace and metal retainer? I ask so I might get a better understanding on how the retainer holds down the edge of the carpet.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
Authorized Pest
Authorized Pest
Someone may have answer to JC's stuff. ITMT, HERE IS a Tech Tip, "on how to install cab windlace without any kinks" in the Interiors Forum.
~ Peggy M
1949 Chevrolet 3804
I purchased the similar items from another vendor. The lower cab windlace retainer only retains the windlace. You appear to have a 1955 1st Series 3/4 ton truck (3604). The cab floor covering was not retained. You need to be able to access the master brake cylinder on the drivers side and the battery on the passenger side. See the floor mat FL-102 on Jim Carters website. PM me if you have specific questions.
Ron - - Dusty53
1954 Chevy 3604
87GN #1544351 04/18/2024 12:53 AM
The earlier version of the metal windlace retainer (pre-'49 or '50. I don't recall when the change was made), can be used to hold down the carpet or rubber mat without having to remove any screws since those retainers screw into the side of the rocker panel instead of the top like yours do. Once you screw the later model retainers in place, you can pry up on the inboard edge with a pry bar to give you enough clearance to tuck the mat or carpet under it. They were not designed for tucking the mat under them, but it can be done if you want to.
Moderated by  ndkid275, Phak1
