1 members (RBs36),
172
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Here's the URL: http://rides.webshots.com/photo/2185549950100824742TQOClX I'm actually rather pleased. It has no brakes. It will start but not idle. Some of the tires may not be suitable for long trips. The dump control levers, including the PTO control, are either not there or not marked, but the bed stayed up for a month after the last time it was raised. It has a bumper hitch already installed! It is difficult to determine the exact position and extent of the driver's seat. (NO SEATBELTS! What were they thinking?) I think that the driver's side airbag may already have been used, too. Other than that, What a peach! Oh, and my wife wants to thank all of you for enriching my life and ruining hers.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I love 1-ton trucks.
Everything I see is consistent with a '52 or '53 except the motor is a '54 or later, and that selenoid on the starter and the ignition resistor probably mean its been converted to 12 volt.
I've never found a sure visual clue that distinguishes a '52 from a '53.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | '53 Chevrolet's had the large series designation side emblems, & no "Chevrolet" emblem. '52's had the "Chevrolet " emblems, & no series designation emblems. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry for my stupidity. This is about the mutt. It has already been determined from the VIN plate and the Engine ID number that the cab is from a 1952 3/4 ton and the engine is from a 1954 1500.
If it wasn't so hot I would go out and look for the number of the frame.
There is very little original about this truck. My wife and I finally identified the seats as being from a late 1960s Volkswagen.
Isn't it cool, though? I mean it both runs (kind of) and dumps!
I forgot to mention that it was all my wife's idea. We have about 15 feet of chat between the front yard and the back yard, and she said it was getting thin.
The engine and ignition system have been converted to 12 volt.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I think that might be bigger than a one ton. Most likely a 1 1/2 or 2 ton. What size tires are on it? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think it truly is a 1 ton.
8 lugs, small fenders, 137" wheel base, and 18" tires all say 1 ton.
Grigg | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | Yeah it's definately a 1 ton, looks just like mine except better LOL. | | | | | Joined: Dec 2005 Posts: 46 New Guy | | New Guy Joined: Dec 2005 Posts: 46 | Wow, I don't spend a lot of time in the big bolt section but I love that truck. I was going to buy a one ton dump 1949 a few years ago but my wife was not as understanding as yours. Thanks for posting the pictures. Bob | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Thanks for your support, Bob. I'll try to keep the photos updated. It looks like this is the kind of project I need, although, at this point, everything that can go wrong does.
I was really happy to see that it had an alternator, even though that made me wonder about the voltage regulator, until I noticed that the alternator doesn't have any wiring attached to it. Apparently it was just used to keep the fan belt tight. Then I broke the head off the tensioning bolt trying to loosen it up to put a new fan belt on. Oh well.
