| | | Forums66 Topics128,288 Posts1,058,581 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Well I finally got the dummy block in and mounted up my trans with the new bellhousing. I put in the new front engine mounts with no problems but I never thought about the trans mount. They make the automatic trans mount for v8 conversions but not for a v8 with the orriginal trans that I can find. Does anyone know of a company that makes a trans mount for the orriginal trans bolted to a v8? Or if anyone has done this to theirs and made a coustom mount. Would you mount it at the end of the block and have the trans hang like orriginal? I am worried about the torque so I am thinking of making a mount that holds the end of the tranny and might make a mount for the end of the block as well. Would that be too many mounts? The reason I kept/rebuilt and went with the orriginal trans is that I wanted to keep the pto for the hoist as well as keep the truck as orriginal as possible other than the engine. Any help would be greatly appreciated! I will add pics in two to three days of the install. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I do not. Just wanted to say, that's a nice truck! And I enjoyed going thru your pictures. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here\'s some that I made to make the V-8 bell fit the old I-6's crossmember. It wasn't too hard at all, just measure 20 times and drill twice, Scott | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Thanks Virginiafiretruck, I enjoyed your pictures as well, awsome restoration. If I'm able to do half the job you're doing I will be very happy.
Very nice mounts Scott, thanks for the picture!
With all the torque from the Stroker,will the trans be fine just using the 4 bolts(grade 8) holding it to the bellhousing and just hanging in the air like orriginal or should I make a mount for the trans as well? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Should be fine with the transmission just hanging there. | | |
