0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1541480 03/24/2024 4:41 AM
1965 C60 rebuild- Two speed rear. Thinking about adding a magnet in the bottom section of the rear end housing. The fluid i pulled out originally was horrible to the point it turned back in to rubber like in the bottom. Got all that removed and scraped out as best i could. Was going to fill with good fluid run it for 50ish miles and change again. Has anyone addded a magnet to the rear to collect metal trash that may have been not caught?
Was thinking about using something like this- anyone have thought? Cannot imagine it would hurt unless it got dislodged although i think that's very unlikely.
Link
1965 Chevy C60 Grain Truck
A magnet stuck to the case, as long as it's in a spot with clearance will stay where it is. Probably not essential, but can't hurt.
AKrause #1541485 03/24/2024 10:01 AM
7
7 Offline
A magnet sure won't do any harm but, If you are not replacing any gears, bearings, shafts, thrust washers, you won't have any more "break-in metal wear". The amount of metal from this point forward will be very minor unless there is a mechanical problem in the assemly.
Very good point about the break in. i would say for sure after 60+ years shes broken in! LOL
H Online: Content
Get the housing clean and dry, and use high temperature epoxy cement to attach the magnet to a spot with plenty of clearance from any moving parts. I recall seeing a donut shaped magnet used in some automatic transmission pans, surrounding a dome shaped projection in the bottom of the pan.
Big ole' speaker magnet.
