7 members (Gray_Ghost, dt235sd, Steelonsteel, Nick in Manitou, frogfarmer, Bill Hanlon, mick53), 103 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#154094 07/31/2007 3:40 AM
Apprentice
Apprentice
Hello guys
Im trying to figure out what my truck is.Im just not sure if it is a 1 or 1.5 ton this is the info i have.
137 inch wheelbase
19.5 tires and rims
5 feet from the back of cab to center of rear wheels
duallie rear end
7 feet from side to side on the duals
9 feet from cab to end of frame rails
helper rear springs
The cab plate is missing and the vin on the title just isnt right
check out the pics hopefully someone knows.
thanks
#154095 07/31/2007 3:49 AM
It's the short wheel base 1 1/2 ton, a 4100 I think. What era truck we talkin' about here?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#154096 07/31/2007 3:51 AM
Apprentice
Apprentice
oopps sorry 54
Im told the grill and fenders are different on the 1.5 ton what size is the grill?
#154097 07/31/2007 5:14 AM
3B Offline
Hy fil shaffer, If the hood comes to a point where the fenders, hood and cowl come together, then it is a 1 1/4-1 1/2 ton, if it's rounded it's a 1 ton, hope that helps.
#154098 07/31/2007 11:41 AM
it's got the heavy duty suspension with optional helper springs on the rear axle i would guess 1.5 ton. previous owner proably changed the wheels to 19.5
#154099 07/31/2007 3:57 PM
3B Offline
Hy fil shaffer, The obvious clue to what you have is the wheels, 5 on the front 10 on the rear did not start until after one ton [which had 8 bolt all around] hope that helps.
#154100 07/31/2007 5:10 PM
Apprentice
Apprentice
cool thanks
