7 members (Hotrod Lincoln, CandoBrent, Forty9, TUTS 59, MikeStone1953, MickeyP, Guitplayer),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Hello guys
Im trying to figure out what my truck is.Im just not sure if it is a 1 or 1.5 ton this is the info i have.
137 inch wheelbase 19.5 tires and rims 5 feet from the back of cab to center of rear wheels duallie rear end 7 feet from side to side on the duals 9 feet from cab to end of frame rails helper rear springs
The cab plate is missing and the vin on the title just isnt right check out the pics hopefully someone knows.
thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's the short wheel base 1 1/2 ton, a 4100 I think. What era truck we talkin' about here? Scott | | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | oopps sorry 54
Im told the grill and fenders are different on the 1.5 ton what size is the grill? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fil shaffer, If the hood comes to a point where the fenders, hood and cowl come together, then it is a 1 1/4-1 1/2 ton, if it's rounded it's a 1 ton, hope that helps. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | it's got the heavy duty suspension with optional helper springs on the rear axle i would guess 1.5 ton. previous owner proably changed the wheels to 19.5 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fil shaffer, The obvious clue to what you have is the wheels, 5 on the front 10 on the rear did not start until after one ton [which had 8 bolt all around] hope that helps. | | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | | | |
