0 members (),
157
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 190 'Bolter | | 'Bolter Joined: May 2011 Posts: 190 | Got a set of running boards at a swap meet that I thought were the short boards for a stake body. Turns out someone had cut down a set from maybe a half ton to use as a stake body set. The boards are in very nice shape, whoever cut them down, cut them probably a couple inches longer than the real dimension they should be. Which leads to my question, does any have the overall length these should be? I would like to fix up the cut end just a bit but don't know how long to make them. Any help is appreciated. Thanks!
Tom | | | | | Joined: Sep 2009 Posts: 5,958 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,958 | Tom, using my phone to try and offer a reply. Check out this page from a 1954 Chevy Master Parts book: http://www.gmpartswiki.com/getpage?pageid=121824I believe the short 3800 running boards are listed here as 40-3/4 long if I’m reading this correctly on my itty bitty screen.  . Looks like 3/4 and 1 ton are same/same for 1947-54.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2011 Posts: 190 'Bolter | | 'Bolter Joined: May 2011 Posts: 190 | Dan, Thanks for that info. The boards I have measure approx. 43 1/2" each, so I have room to cut them down a bit and rebuild the ends to look like more of a stock finish. With a little metal work and some fresh paint they should look good when done. Thanks again for the measurement.
Tom | | | | | Joined: Sep 2009 Posts: 5,958 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,958 | Glad it helped!  Maybe when you get your mod done you could come back and post a few pics along with any tips that may come in handy for other Bolters should they need to do something similar.
| | | | | Joined: Dec 2021 Posts: 9 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 9 | I've a set of 51s, I measure in the morning. | | |
