0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#1540939 03/19/2024 8:39 PM
Got a set of running boards at a swap meet that I thought were the short boards for a stake body. Turns out someone had cut down a set from maybe a half ton to use as a stake body set. The boards are in very nice shape, whoever cut them down, cut them probably a couple inches longer than the real dimension they should be. Which leads to my question, does any have the overall length these should be? I would like to fix up the cut end just a bit but don't know how long to make them. Any help is appreciated. Thanks!
Tom
Tom, using my phone to try and offer a reply.
Check out this page from a 1954 Chevy Master Parts book:
http://www.gmpartswiki.com/getpage?pageid=121824
I believe the short 3800 running boards are listed here as 40-3/4 long if I’m reading this correctly on my itty bitty screen. wink. Looks like 3/4 and 1 ton are same/same for 1947-54.
~ Dan
1951 Chevy 3 window 3100
Dan,
Thanks for that info. The boards I have measure approx. 43 1/2" each, so I have room to cut them down a bit and rebuild the ends to look like more of a stock finish. With a little metal work and some fresh paint they should look good when done. Thanks again for the measurement.
Tom
Glad it helped! thumbs_up Maybe when you get your mod done you could come back and post a few pics along with any tips that may come in handy for other Bolters should they need to do something similar. wink
~ Dan
I've a set of 51s, I measure in the morning.
