6 members (Napco Man, Gray_Ghost, Phak1, Otto Skorzeny, 1955 1 Series, Southerntruck), 114 guests, and 3 robots.
Topics128,110
Posts1,056,242
Members48,437
#153973 07/22/2007 2:13 PM
I just was given what is supposed to be a 46 big bolt. Is definitly the right body style and all and is titled a 46, has a 2 speed rear and was shortened way up and used to skid logs out of the woods! Now here's my question, PO said it has a 5 speed trans? I have not seen one with a 5 speed before and as this thing is free but not running I can't be sure, yet. I am bringing it home today though and hope to find out then. Was this an option back then?
#153974 07/22/2007 3:03 PM
yep. 5 speed spicer tranny. super heavy duty type of gizmo. gear number 5 was NOT overdrive, but rather direct, however, the gear set is available to make 5th gear overdrive.
big ol' heavy duty cast iron mamma-jamma. maybe a big ol' heavy duty lipe clutch plate an pressure plate in front of it.
the kind of thing you would find on a log skidder.......
#153975 07/22/2007 3:56 PM
My 57 6500 has a 5 speed and a 2 speed which is a first for me. Am I correct that some old bolts came with 5 speeds from the factory?
#153976 07/22/2007 4:25 PM
When I first looked at my 56 I was told that it was a 5 speed turned out to be a 4 the standard SM420. I had planed to put a Fuller 6 speed in it but now think I will use a spicer 5 speed overdrive it will be the easer install as the spicer comes with a drive line brake like the SM420 and I have been told they were used from the late Forty’s to the early Ninety’s.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
