| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | I just was given what is supposed to be a 46 big bolt. Is definitly the right body style and all and is titled a 46, has a 2 speed rear and was shortened way up and used to skid logs out of the woods! Now here's my question, PO said it has a 5 speed trans? I have not seen one with a 5 speed before and as this thing is free but not running I can't be sure, yet. I am bringing it home today though and hope to find out then. Was this an option back then? | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | yep. 5 speed spicer tranny. super heavy duty type of gizmo. gear number 5 was NOT overdrive, but rather direct, however, the gear set is available to make 5th gear overdrive.
big ol' heavy duty cast iron mamma-jamma. maybe a big ol' heavy duty lipe clutch plate an pressure plate in front of it.
the kind of thing you would find on a log skidder....... | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | My 57 6500 has a 5 speed and a 2 speed which is a first for me. Am I correct that some old bolts came with 5 speeds from the factory? | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | When I first looked at my 56 I was told that it was a 5 speed turned out to be a 4 the standard SM420. I had planed to put a Fuller 6 speed in it but now think I will use a spicer 5 speed overdrive it will be the easer install as the spicer comes with a drive line brake like the SM420 and I have been told they were used from the late Forty’s to the early Ninety’s. | | |
