| | | Forums66 Topics128,165 Posts1,057,086 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | I am restoring the instrument cluster on my 1957 3100. I had the speedo rebuilt and had to replace the big chrome bezel. The lens was attached using some sort of black adhesive in the 4 slots provided in the bezel. That adhesive is no longer functional. And suggestions or recommendations as to what to use to hold the lens in now? Thanks in advance!
1957 3100, 235 with 4 speed floor shift
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No adhesive. It's retained by 4 short "rubber" strips/bumpers/spacers. Probably single side or double side sticky. Look at used 55-59 cluster parts for sale on Ebay, you will see the old worn out "tape" or it's witness marks on the mask plate. The lens is more or less retained by assembly pressure. I think one sided sticky would be best."Weather strip"/ door seal/ HVAC stuff. Maybe something like this THIS
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | We have a Tech Tip in the Back Room on Refurbishing Dash Gauge Cluster with some good step-by-step instructions and images. Part of that Tip: 8> I needed and ordered a new gauge cluster glass face, bezel, and rubber gasket. (If they are not needed, at least order a new rubber gasket as it will make it so much easier to place back together, as the gasket "gives" when you are replacing the bezel. The old gasket is hard and the possibility of the glass being broken increases.)
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | Excellent. Rubber. I should have known. Makes it much easier. Thanks to you both!
