0 members (), 109 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#1538232 02/27/2024 1:28 AM
Water pump is failing on my 1949 Chev Truck. The engine is from a 1954 Bel Air power glide. Ordered a Carter water pump from Rock Auto and thought everything was good. Started looking at the distance of the pulley from the engine and the width of the pulley that the belt rides in and it's different. Won't work. The bully width is wider than the water pump that came off the truck and the pulley distance from the engine is about 1/4 inch more, so the belt won't line up with the lower pulley and alternator. Looking at other water pumps from parts stores, I can't tell if they will work or not. How can I know that I'm getting the right water pump when ordering? These are supposed to be for a 1954 235 engine.
Darrell
Car water pumps in 54 used a 3/8 inch wide belt. Trucks used 5/8" belts, I believe. Is the pulley pressed onto the pump shaft, or does it bolt onto a round flange?
I think in 1954 the water pumps had the 3/8 pulley at least that is what was on my 54 trucks original engine.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
It's pressed on.
The water pump sold by most vendors is available with a wide pulley using a 5/8” belt (older engines) or a narrow 3/8” pulley (for 1953 and 1954 engines). Some vendors ask you to specify which one you need. I would not try to swap the pulleys, get the correct one.
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
Thanks. Looks like American Classic Trucks has the 3/8 belt pulley. I'll try ordering from them. I'm surprised the Carter water pump from Rock Auto didn't have the 3/8 belt pulley since it is specifically for a 1954 Chevy Belair 235 engine.
Anyone know what the items are called that the heater hoses connect to on the head and the water pump? I think mine has the 3/8 threaded pipe into the water pump and 5/8 connector for heater hose. I need to replace mine. They're all corroded and I don't want to reuse them.
O Online: Content
They're pipe nipples. Take the old ones to the hardware store or plumbing supply to compare. Or make your own.
1950 Chevrolet 3100 (Ol' Roy)
Darrell Day, In the 1929-53 Chevy Master Parts Catalog they are listed under Parts Group# 8.866 - Connections, Hot Water Heater.
More specifically listed under that Parts Group as: Nipple, heater coupling (3/8) GM# 3106066
Chev's of the 40's carries a reproduction piece under Heater Hose Nipple with the same ID number as the original GM part number.
~ Dan
1951 Chevy 3 window 3100
The connectors should be available at most local parts suppliers. NAPA sells a 5/8 inch heater hose connector number NOE 6601737 for under $10.00
Unfortunately not in my area. I've been to Oreilly's, NAPA, Auto Zone and the local plumbing and electric store that has about everything and none of them had them. I found some online.
Would your local NAPA not order the NAPA part number " NOE 6601737 heater hose connector" for you?
No1300, They probably would have. I didn't ask them. I thought I would be able to find some locally somewhere, so I didn't ask them to order. On another note, I'm having trouble finding the correct water pump for this engine. I have the 235 out of a 1954 Bel Air with power glide. I ordered a replacement from Rock Auto and it came with a 5/8 belt pulley drive. Mine has a 3/8 belt pulley drive. The 5/8 is offset from the 3/8, so the belt would not line up with crank pulley and alternator pulley. Sent that one back and ordered one for the engine from Oreilly's and it was advertised as 3/8 belt pulley, but it was just like the one from Rock Auto. A stop at Advance Auto Parts also produced nothing. Stopped at Auto Zone and it looks like they might have one that will work. Won't know until it shows up tomorrow.
Anyone know where I can source a water pump online for this engine that will work?
Darrell
O Online: Content
You'd be better off rebuilding the pump that was on the engine already.
Send it off to The Flying Dutchman or Then & Now Automotive to rebuild it for you if you don't want to do it yourself.
New parts are Chinese garbage anyway even if you do find one that fits.
I ordered mine from Jim Carter truck parts. rock auto and a few other spots seemed to be out of stock ,this was last November.
"The Journey"
Follow in the DITY
H Online: Content
Can’t say I used this GMB water pump, it is just sitting on my shelf…
Pic attached in link
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1405192/gmb-brand-water-pump.html
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
What Otto said... send your old waterpump off to be rebuilt. Better than new and you know it will fit. NAPA sent mine off and I had it back in a few days.
The "new" ones are offshore junk.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Darrell, check Oriellys again.....with a good countet man. Ive purchased two from them......and you can check before you pay. Mine came overnite and this hasnt been long ago..... and price was good and no shipping.
I recently purchased a water pump from ebay with 3/8 inch pulleys. The manufacturer was GMB, part number was 130-9710. I have also purchased from Jim Carter Truck Parts. Both vendors specified pulley size.
I believe the GMB 130-1043 water pump is the 5/8 inch version for the early engines. That 5/8 inch pump is usually cheaper than the 3/8 inch one.
Maybe ask napa. I've had good luck getting those type of parts from them . Might be worth a quick phone call to see. Maybe they can confirm specs on pulley for you.
1950 Chevy 3100
J Online: Content
These guys quoted me a water pump rebuild kit. Rebuilding yourself shouldn’t be a big deal.
https://cowboyjohnsautoparts.com/
I didn’t end up ordering due to some other priorities that came up. Can’t speak for quality.
1951 3100
