1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#153707 07/07/2007 3:06 AM
Apprentice
Apprentice
Hi guys
I have a question about my heater in my 54.
It has the two heater hoses going in the firewall and into the box. but what has me puzzled it has no blower?
There is a block offplate there and it looks original.
any ideas
#153708 07/07/2007 3:09 AM
it is under the dash, the plate is for the deluxe heater, you must have the std unit
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#153709 07/07/2007 4:32 AM
Apprentice
Apprentice
So it just has the hot water run through it and the heat just lingers arund the cab.
If im thinking correctly
This truck really didnt have anything when it was made first we found out no oil filter and now no blower whats next. hahaha
#153710 07/07/2007 8:42 AM
V
V Offline
I have found many surprises in restoring the old stovebolt truck. Welcome.
Good luck and send pictures!!! gotta love pictures...
#153711 07/12/2007 7:22 PM
I just rebuilt my standard heater it has a small fan and motor under the circular housing within the heater core. I found that since my truck had been sitting a while the bottom tube where it entered the core had a weeper. It is really easy to restore, remove it by removing the nuts on the studs and disconnecting the one wire to the switch. Look for evidence of leaks and fix, I cleaned and repainted all the housing and it looks good. If you want to covert to 12-volt motors are available for that too!
