0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Hi guys
I have a question about my heater in my 54. It has the two heater hoses going in the firewall and into the box. but what has me puzzled it has no blower? There is a block offplate there and it looks original. any ideas | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | it is under the dash, the plate is for the deluxe heater, you must have the std unit | | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | So it just has the hot water run through it and the heat just lingers arund the cab.
If im thinking correctly
This truck really didnt have anything when it was made first we found out no oil filter and now no blower whats next. hahaha | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have found many surprises in restoring the old stovebolt truck. Welcome.
Good luck and send pictures!!! gotta love pictures... | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I just rebuilt my standard heater it has a small fan and motor under the circular housing within the heater core. I found that since my truck had been sitting a while the bottom tube where it entered the core had a weeper. It is really easy to restore, remove it by removing the nuts on the studs and disconnecting the one wire to the switch. Look for evidence of leaks and fix, I cleaned and repainted all the housing and it looks good. If you want to covert to 12-volt motors are available for that too! | | |
