1 members (Hotrod Lincoln), 92 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
#1535251 02/02/2024 7:56 PM
So I'm trying to get oil to rockers by turning motor over with crank pulley. Will this not pump oil enough? Spark plugs are removed so it turns easily. But no oil to rockers. Plugs installed on on passageways on drivers side. No oil at oil pressure port either.
no, not likely. You need to spin the oil pump. Pull the distributor and make a oil priming tool out of an old spare distributor, or get a wood handles screwdriver, remove the handle, check the shaft into a drill and spin the oil pump.
Mike
Did just that. Have oil flow now. Thanks
H Online: Content
Use a 1/2" capacity corded drill motor- - - -not some weak sister rechargeable. When the pump loads up and the pressure rises, be sure to have a good grip on the handle.
Got really good flow except for one rocker. It didn't seem to want to flow just oozing. Tried cleaning with brake cleaner but no better. I guess my question is do you think it will flush out at some point? I really don't want to disassemble the rockers for just this one rocker. Thanks for your advice.
I'd rather do it now rather than wait until things go south!
BC
1960 C60 pasture art
When I was doing this last year on my 235 ,I jiggled the rockers around and bumped them with a rubber mallet untill I got them all oiling.
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Which rocker? If it is not at the very front or the very rear one, I would blow compressed air into the weep hole on the rocker.
If the weak rocker is at the end, you should remove the rocker assembly and thoroughly clean the inside of the rocker shafts.
When I do that, I knock out the plugs in the ends of them so that I can remove every speck of crud.
Fourth from the front. It's got a little but nothing near as much as the rest of them. I'll try the compressed air.
Well it was driving me nuts so I took it all apart and cleaned it out. Wasn't much in the tubes but I know it's clear now. Kept everything in the same place and reassembled.
H Online: Content
Didn't Shakespeare write a play about being concerned over stovebolt rocker arm oiling- - - - - -"Much Ado About Nothing"!
LOL!
Agree Jerry. I worry to much according to my wife. But the bills get paid and she just thinks it's magic I guess. Would not know what to do with out her though.
Well at least now you have the piece of mind that there isn't any crud in your rocker shafts and there isn't any scoring on your shaft or rocker arms.
