1 members (Chip O), 77 guests, and 6 robots.
Topics128,181
Posts1,057,189
Members48,465
Wondering if it changes gears properly? New clutch in. Sitting still with motor off clutch compressed I can go through all gears easily. While driving and changing gears, I can’t move it into the next gear until the motor rpm slows down enough. Sort of like letting the gears synchronizing.
Also, what is this bolt used for? I changed the transmission oil yesterday & saw this.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
O Online: Content
How did it shift before the new clutch was installed?
Synchronizers might be worn out.
1950 Chevrolet 3100 (Ol' Roy)
Otto, About the same.
So that would require removal & taking apart?
That bolt / plug is for putting gear oil in for the universal joint .The 4 spd has the plug the 3 spd I understand the Speedo hole is used to fill
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
The 3 speed also has a plug for putting gear oil into the u-joint area. It also serves to secure the rear bushing in the transmission case.
Does it change gears if you double-clutch it? Clutch it once to take it out of gear and release the clutch. Clutch it again to put it in the next gear. ????
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
If you have to wait for gear speed to match up, the clutch is not releasing fully. Recheck your adjustment. There should be about 3/4 inch of pedal travel before the throwout bearing contacts the pressure plate fingers.
