0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Wondering if it changes gears properly? New clutch in. Sitting still with motor off clutch compressed I can go through all gears easily. While driving and changing gears, I can’t move it into the next gear until the motor rpm slows down enough. Sort of like letting the gears synchronizing.
Also, what is this bolt used for? I changed the transmission oil yesterday & saw this.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
How did it shift before the new clutch was installed?
Synchronizers might be worn out.
1950 Chevrolet 3100 (Ol' Roy)
Otto, About the same.
So that would require removal & taking apart?
That bolt / plug is for putting gear oil in for the universal joint .The 4 spd has the plug the 3 spd I understand the Speedo hole is used to fill
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
The 3 speed also has a plug for putting gear oil into the u-joint area. It also serves to secure the rear bushing in the transmission case.
Does it change gears if you double-clutch it? Clutch it once to take it out of gear and release the clutch. Clutch it again to put it in the next gear. ????
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
H Online: Content
If you have to wait for gear speed to match up, the clutch is not releasing fully. Recheck your adjustment. There should be about 3/4 inch of pedal travel before the throwout bearing contacts the pressure plate fingers.
