| | | Forums66 Topics128,079 Posts1,056,306 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | need to replace 2 cab light bulds on my 48, unscrewed the tops but still wont come off??? are they screwed from the inside?? dont want to brake them help? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Once you take those two screws out, the bezel should lift off, then remove lens to get to bulb. Might be stuck, with rust. To remvoe the light assembly, the screws run through the base of the light, into the top of the cab. | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok the great spankster ideas on how i can get them off?? thanks man | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 48loadmasterguy, different light manufacturers attach their lights to the cab in different ways, Spanky has explained one way, check to see if there are more screws securing the base to the cab, if you find none then the base is probably stuck to the top of the cab, I've had to pry them off and ended up with half the gasket on the base and half stuck to the cab roof, good luck, hope that helps. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Donnie, Ill bet the lens has "glued" itself to the gasket/base.Probably from sitting in the sun and elements over the years. Maybe try some WD 40 or other solvent around the bottom of the lens and see if that dont loosen it up? | | |
