6 members (Gdads51, Otto Skorzeny, TUTS 59, amtrakjoe, fonz8261, mk72), 78 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#1534203 01/25/2024 8:51 PM
I have a 53 half ton truck and after a short drive my truck won't crank. How do I troublshoot my ignition switch or starter switch? Thanks, Scott
If it won't crank, it's either the starter switch itself which may have pitted contacts, or possibly the linkage from the pedal to the starter switch. I'm assuming it has the stock stomp starter.
It could also be the starter needing rebuilding. If it lands on a bad spot on the commutator, it may not spin up.
I don't believe it would be the ignition switch, unless someone has converted it to a key operated starter with solenoid.
O Online: Content
What do you mean by "won't crank"? Does the starter not turn over at all? Could be your foot pedal. Turn the key to ON, go under the hood and engage the starter manually by moving the rod from the pedal. Check all your ground connections; battery to frame, engine to frame, etc. Make sure battery is fully charged to 6.5+ volts. Is your battery to starter cable 00 gauge? If not, replace it.
1950 Chevrolet 3100 (Ol' Roy)
"Cranking" is the is the action of the starting motor turning the flywheel, which spins the crankshaft. "Starting" is the fuel burning and making the engine run after the starter is disengaged. Troubleshooting a failure to crank is entirely different from correcting a failure to start and run. Can you be a little more specific about what the problem is? Certain situations like a low battery can cause both problems.
Sir Searchalot
Sir Searchalot
Scott,
As others have said, some folks use the term "no crank" it different ways. So assuming you mean the starter won't spin at all and assuming foot start.....
1. Check the battery for voltage. If battery OK and it's not breaking down. (Should be load tested) then...
2. Check ALL battery cable connections, neg and pos, both ends, for loose, corroded, broken. if good, then.....
3. Key off, neutral, E brake on, center plug wire off distributor, push the button on starter down by hand or wooden lever, to see if stater spins. Don't use the foot start mechanism.
4. No spin....and if you did 1 thru 3 correctly.......it's that switch on top of starter or the starter.
Report results before changing anything so we can continue the test procedure.
It's important no tell us of ANY noise from starter area. Also be aware that a bad battery cable connection for pos or neg or ground bolting or bad cell does not show up by just checking battery voltage across battery posts.
"No start" is different as Jerry said. It means the starter is spinning but motor does not fire or it fires but won't run.
If you meant something else, just restate it carefully and we will respond to that.
Thank you for replying. The linkage works. My wife pushed down on the starter pedal and I watched it contact and push down the switch on the starter. Battery is fully charged. I will remove switch and either replace or repair.
Thanks. Battery charged. Not sure about the gauge of battery cable. When I turn ignition key and stomp on pedal nothing happens. Stomper linkage good. Bad switch?
Jerry, thanks for replying. When I stomp on starter pedal and ignition key is on nothing happens. Battery fully charged, stomper linkage and contact with starter switch ok- I watched as someone depressed pedal.
Bad starter switch?
Thanks. Battery fully charged. Will check connections. When ignition key is turned on and starter pedal depressed nothing happens- no sound.
I will try the test you suggested. Thanks again.
O Online: Content
Move the starter lever under the hood by hand with the key "on" and see what happens.
I haven't heard back from you about Bartamos' test #3 which tests the switch making electrical contact with the starter motor. Sometimes the heavy copper lugs in the switch fail to make contact with the copper lug on the starter due to wear, corrosion or simply from linkage wear.
Actuate that button on the starter switch by hand. If the button is depressed fully and the starter motor does not spin effortlessly under this no-load condition, then you have a starter switch/starter problem.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Finally getting back to truck. I replaced the switch and followed your suggestions but still nothing. Ignition on, depress starter pedal and nothing happens. No sound. Starter motor?
Thanks.
i would test the starter switch for power when pressed. Then check the end of the wire at the starter when pressed.
I am new to working on engines so what's best way to check for power? With a multimeter?
Thanks.
Sorry about the delay. I replaced the starter switch yesterday and when I depressed the switch by hand nothing happens. No sound. I will test to be certain the switch is getting power from the ignition but it seems my starter may be bad. Are rebuild kits available?
O Online: Content
Yes. There are also options for rebuilding services if you don't have a decent auto electric shop near you.
You can also buy a brand new 6v starter from NAPA for about $80. I just installed one in my truck and kept the original 1950 starter for future rebuilding. Picture below.
Both vendors below sell rebuild parts and offer rebuild services
Then & Now Automotive
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.then-now-auto.com/
Atwater Kent Temp sending units, coils, fuel sending units, tube radios, vacuum advance, voltage regs, starters 1920s to 1970s (mostly 30s, 40s, 50s)
12 Jacques Street Worcester,
MA, 01603
(508)792-9500
http://www.mykmlifestyle.com
Thanks for the info.
Latest: power to starter switch good. Pulled starter and had it bench checked and it's fine. Replaced starter and nothing. No sound. The mechanic that bench checked it is not impressed with the new parts - starter switch is new- they don't make them like they used to..
Could it be the linkage ?
Will do.
The linkage should push the button on the switch that makes contact with a brass lug under the switch. .Sometimes the brass lug gets worn from contact(sparking) try to push the button using a pry bar being careful not to damage your new switch
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Ok, Confirm the Thick Black wire is "Positive "? Usually red but not always, that is bolted to the starter? Also, check your ground or Grounds. Those old thin "mesh" type are not a great ground at all and corrode easily. The picture seems like the stomp starter, if no one was inside when picture was taken ( the "relaxed" position should be way further back towards the firewall..
1950 Chevy 3100
O Online: Content
Grab hold of that rod from the foot stomp with your hand and push the starter button manually. What happens?
Make darn sure that the tranny is in neutral before doing this.
It is interesting that our web site changed a word in the previous sentence.
Do the headlights and other electrical accessories work? There is probably a loose or dirty connection on the ground side that you haven't found yet.
Check the voltage at the starter terminal while someone pushes the start button. If it drops, then you have a poor connection upstream and you need to pull the battery and ground connections and check/clean them.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
A circuit needs to be complete for something to work. If you've checked the battery post connections, then check the other ends of the cables. With your multimeter, check across each connection: battery post to clamp (positive and negative), battery ground cable to frame, ground strap to engine bellhousing, and ground strap to engine block. If you get more than 1 ohm across any of them, then clean them and reconnect. Connections can be good enough to operate small loads (lights, etc.) but fail to provide enough power for larger loads such as the starter.
1 ohm would limit the current to 6 amps, no where near enough to cause the starter motor to turn. Each connection needs to be way lower than 1 ohm.
O Online: Content
Shaffer1950 pointed out on page 2 that the starter lever was too close to the starter button - practically resting on top of it.
It should look like this when your foot is off the stomper.
Thanks. Will look.
That is what mine looks like. I think I have a bad new starter switch and I found a new old switch on Ebay that I will replace with.
Realized the battery was 6 years old. Replaced with new 12 volt battery. Started up immediately. Ran rough a few minutes as it hasn't run lately. After 3-4 minutes died.
Might be out of gas but won't start. In other words, no sound when ignition on and floor starter depressed.
Must be something loose?
Replaced battery as realized it was 7 years old. Started right up. Ran rough and quit after 3-4 minutes. Might be out of gas. Anyway, won't restart. Same issue as before with no sound when ignition on and pedal depressed ( starter bench checked good and starter switch replaced). I know there is power going to the starter via test light. How do I use a multimeter to check volts at starter?
Ignition on, red on starter and black to a good ground?
Thanks.
This is late but my problem turned out to be bad contact surface between starter switch and starter. Once I cleaned them up it fired right up.
Appreciated all the advice.
