Apparently that application of the 292 did not use a rear sump oilpan, they used a center sump instead and I need to know where the dipstick was located on that block so I can drill my engine to work with that oilpan. Thanks John
If the standard location between the starter and fuel pump isn't correct, then that info is probably going to need to come from someone with a 292 Tilt Cab.
Mike B
Mike Boteler
1956 Chevy 3100 Resto Rod 1952 Willys M38 Army Jeep 1983 Jeep CJ7 Laredo 1984 Jeep CJ7 +++++ Silver Spring, MD
I don't think there are to many Tilt Cab COE guys on the Stovebolt (I had two, but they were both V engines). You might try the ATHS web site as they are more of a BIG Rig group.
Mike B
Mike Boteler
