6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1535328 02/03/2024 1:21 PM
I am looking for information for 292's used in COE applications in the 60's or 70's. Are there any out there?
Welcome to Stovebolt wave
Exactly what type of info are you looking for?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Apparently that application of the 292 did not use a rear sump oilpan, they used a center sump instead and I need to know where the dipstick was located on that block so I can drill my engine to work with that oilpan.
If the standard location between the starter and fuel pump isn't correct, then that info is probably going to need to come from someone with a 292 Tilt Cab.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Is there anyone out there with a 292 in a Tilt Cab?
I don't think there are to many Tilt Cab COE guys on the Stovebolt (I had two, but they were both V engines). You might try the ATHS web site as they are more of a BIG Rig group.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
In-line COE intake manifolds are designed for updraft carbs and are upside down to downdraft carb manifolds.
Ed
Go on ebay and purchase you a Dealer Brochure on the year you want in question. This 1969 Chevy Tilt Cab Brochure is on there now for $10.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
If you're on Facebook, I have a Facebook group Page dedicated to these trucks called, 1960-1980 Chevrolet & GMC tilt Cab Trucks Only.
Spanky Hardy
1950 GMC 250 1-Ton
