1 members (Hanks custodian),
264
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 128 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 128 | I had to replace the rear main seal in my 1948 Chevy pickup, which has a 1954 235 out of a Belaire. In doing so, I had to remove the transmission and drop the crankshaft a little. Can someone tell me what the torque specs are for tightening the bolts on the main bearing caps? I've seen 100-110 ft/lbs, but want to make sure. That's what my manual shows for a 1949. I don't have any information on a 1954.
Thanks, Darrell | | | | | Joined: Sep 2009 Posts: 5,872 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,872 | Darrell, Check out this older thread on your Main Bearing Cap torque settings. I think that should help answer your question.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | I just checked the 55 2nd series truck shop manual and it calls for 100-110 ft-lb for the main bearing caps on the 235. Should be the same on your 54 235 engine.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2018 Posts: 128 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 128 | Thanks everyone. Cranked them down to 90 foot pounds and the crank wouldn't turn. Upon further investigation, the caps have shims. We're going to have to back up and punt. Probably need to plastic-gauge and re-shim the caps. | | |
