3 members (Chris's 46 / 515, 59 fleet, Wally / Montana), 138 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
#1530195 12/22/2023 11:06 AM
2 Offline
Is this the correct part number for the fuel tank on my 56 chevy 6100 ? # 3719479
I'm pretty sure it is.... maybe....
1956 Chevy 6100 with a dump box
Story in Big Bolts
1949 ford 8n tractor
1958 861 diesel ford tractor
2003 honda vtx 1800 c bike
2thirstychevys #1530199 12/22/2023 12:18 PM
7
7 Offline
That appears to be the correct tank, lot of vendors have it, you probably want a new sending unit/strainer assembly also.
78buckshot #1530228 12/22/2023 3:45 PM
2 Offline
Thank you buckshot for the info, I couldn't agree more on the sending unit ( it was very disgusting )
Story in Big Bolts
That's the correct tank for the 1/2 to 2 ton trucks. The 2-1/2 ton trucks had the 21.5 gallon tank p/n 3729086...if you find one of those, remember to get the filler neck as well as they are not the same as the 17.5 gallon neck.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1530338 12/23/2023 3:34 PM
2 Offline
Thank you Mike that's good information to know, saves a headache at installation time thumbs_up
Story in Big Bolts
2 Offline
Well not looking good for that particular tank but found one for a 56 chevy 3800 261ci , spectra number gm55b . Dimensions are 54 x 12 1/2 x 6 1/2 18 gallons. There were a few others listed ( spectra ) but couldn't get the numbers to show up on the spectra site. After the holidays I'll just call spectra... thinking
Story in Big Bolts
FWIW this is the tank I bought for my 56, 6100
Dorman 576-245 Fuel Tank Compatible with Select Chevrolet/GMC Models
https://a.co/d/jdbbuVl
2 Offline
Thanks Doug I had looked at that one earlier but couldn't find capacity for it, but it does cross to the gm55b at 18 gallons and a great price nanner now I can stop looking computerdeath
Story in Big Bolts
2 Offline
dorman tank specs
This will work thumbs_up
Story in Big Bolts
L x w x h x .0043 will give you the gallons.
Achipmunk #1530454 12/24/2023 4:04 PM
2 Offline
That's pretty good thumbs_up you get to skip the conversion from cubic inches to gallons! Thanks
Story in Big Bolts
2 Offline
I finally got the new fuel tank installed last week and it went very well, also new sender and fuel supply lines with plenty of anti rattle material on the tank and straps. Only issue was the sharp corners of the tank which I did round off, this being a spectra GM55B tank 18 gallons and I also added a clear inline filter too
Story in Big Bolts
Out of curiosity, did you coat the inside of it with IIRC it's called Red Coat gas tank liner? It's a super sticky red epoxy kinda stuff that will keep the tank from rusting, forever. It'll even hold up to bad gas so if the rig ever sits, you can just clean and flush it with new gas versus replacing the rusty tank again. It's not cheap, a quart of it is $35, and you might need two.. but it's cheap insurance.
This stuff.. https://www.ebay.com/itm/134744769523
Tronman #1536987 02/17/2024 10:53 AM
2 Offline
Tronman,
Thanks for the info on red coat I've never heard of it before so to answer your question , no I didn't coat it. It's worth considering but I just don't know if I would, it will be coming back out again when I'm ready to remove the cab so maybe then ( about a year from now)
Story in Big Bolts
