1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1535246 02/02/2024 6:57 PM
Chevy 250 IL 6. 4 run short bursts like 1 maybe 2 minutes the 1 st day just to see the timing with the strobe. After putting the radiator in yesterday & getting the hoses on today. I poured 2 gallons of antifreeze on it, then I heard water pouring out from motor dripping out on the manifold flange. I isolated where it’s coming from and I think it’s bad. A stream of water is shooting strait out from what appears to be beneath # 3 intake/ exhaust stud.
Cracked head?
It has not been used since refurbished last summer. Guess I should notify the shop mechanic.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
I just spoke with the shop machinist. He thinks there is a freeze plug in that area in the head. Ever heard of that?
Three of them if I remember correctly.
Mike
Your first picture shows the freeze plug pretty clearly, even if it's out of focus pretty badly. I'd suggest changing all of them while you have the manifolds off. Use brass plugs if you can find some the right size- - - -they don't rust out.
Thanks Jerry! Darn frustrating. The machinist should have replaced those i would have thought (for the money it cost)!
Hopefully I can get her torn down again soon.
Do these go in with any sealer or something?
At least I won’t have to pull the head off!
glennj3 #1535279 02/02/2024 11:00 PM
What did the machinist do for you?
He serviced the head last year in preparation to rebuild the motor.
Riding in the Passing Lane
Put a thin coating of RTV on the new freeze plugs. It will seal the plug also help the plug go in smoother.
George
1972 Chevy c10 Cheyenne Super
The little culprit😖 I hope they are readily available locally.
What size is it ?
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Originally Posted by fattboyzz
What size is it ?
The ones I removed had no size or #. The local parts store had ones close but too small. Another across town had 1 that actually fit. It Dorman 555-016! 2 others coming in tomorrow afternoon.
I put the one in and it looks satisfying for me!
Just bothered that the machinist was paid $400 to do a routine head service last year and he didn’t change those out.
Thanks George. I put the one in with blue RTV. Nice tight fit. I get the other 2 in tomorrow.
Is the old one rusted out?
The one that was leaking was. See the picture. Perfect small hole. None of them was easy to remove though.
What size is it ?
Sorry I thought I’d posted. .016
Nice tight fit.
