1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1533816 01/23/2024 2:39 AM
I have several hundred pounds of lead flashing left over from commercial building projects. Can I melt this into sticks for lead filler on bodywork or is it the wrong alloy?
mick53 #1533820 01/23/2024 3:05 AM
H Online: Content
The short answer is no. Body "lead" is actually solder, with anywhere from 10% to 30% tin in the mix. The more tin, the better quality the filler will be. Then you'll need to spend a few years perfecting your technique at applying, smoothing and finishing the filler, and hoping you can use enough baking soda to neutralize the acid you use to prep the metal. If not. the acid will bleed through and lift the paint after a few months. Also- - - -don't use anything other than nitrocellulose lacquer over lead filler.
I cast target bullets by the thousands and mix my own alloys- - - - -want to sell that lead? I'll be in northern Indiana sometime in the next few months.
Thanks Jerry. I will just melt it down and use it for weights. It's not getting any easier to come by. I have a friend that owns a large scrap yard and he won't even sell it to me.
