7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible), 108 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
We are trying to find a radiator for our 51 GMC 100.
When I am looking on ebay I get one for a 51 Chevrolet 3100 and 3600.
Anyone know if it will work?
1951 GMC 100
First attempt on a restoration
I didn't look. I'll look and let you know.
1951 GMC 100
Thank you.
1951 GMC 100
B Online: Content
Chevy radiators won't fit for 2 reasons.
1. The GMC engine is about 1.5" longer, all towards the radiator. There was a brand new Chevy radiator in my '52 GMC when I bought it. There was not enough room to get the fan belt on or off without removing the radiator. Being cheap, I removed the radiator, took it to a radiator shop and had the flanges on the sides redone to move the core forward.
2. GMC radiator fill spouts come horizontally off the top tank, then curve up. A Chevy radiator has the filler on the top, which ends up being inaccessible under the top of the radiator support (6.0450 below). While I had the radiator flanges being modified, I had the radiator shop remove the top fill and put a 90 degree filler on the engine side of the top tank as shown in the picture below.
Any modern replacement for a GMC radiator will use a pressure cap on the fill spout, not a separate pressure valve as shown just to the left of the top radiator hose connection in the picture below.
Thank you for the great information.
I'm having a hard time finding a radiator that is for our truck that doesn't cost a small fortune.
1951 GMC 100
I haven't actually seen it. My husband wants to get a new one.
I'll try taking a look at it in the morning.
1951 GMC 100
I see some for V8s on that auction site. Will they work on a 6?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
I got a aluminum one from Champion Radiator for my GMC 100 and it was a bolt in no adjustment needed. Like Bill Hanlon said you need a GMC radiator.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
We are using the original straight 6.
My son and husband got it started!
1951 GMC 100
Glad I didn't order the chevy/gmc one on ebay.
When we put our truck information in, it claims that it fits.
The measurements from the ones on classic parts, are different.
1951 GMC 100
I check out our radiator. It is a harrison 125505 radiator.
Any suggestions?
1951 GMC 100
Professional procrastinator
Try Jim Carters
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Out of stock at $595...
1950 Chevy 3100
My husband is convinced the one on ebay will fit.
I'll order it, but I'm not holding my breath. 😁
1951 GMC 100
B Online: Content
Please post a link to the eBay radiator you purchased.
This is the one my husband thinks I should order.
My issue is, if it doesn't fit, we have to pay for return shipping.
I bet that won't be cheep. 🙄
https://www.ebay.com/itm/2957908920...r=&widget_ver=artemis&media=COPY
1951 GMC 100
Note that the text within the ebay add it states : For V8 Conversion ONLY
I do not think this 3 row radiator will work in the stock set-up. You may not have clearance for the fan/waterpump.
Recommend you not order the ebay radiator.
You may consider calling LMC Truck tomorrow , 800-562-8782 , ask about their Mishimoto Alum Radiator 32-2900, $385.95, In stock ( or so it says online ) . Online it shows it fits your application but I suggest you call and verify that it fits your application , year, models, etc... by talking to a sales person.
Ron - - Dusty53
1954 Chevy 3604
My guys here in the garage thought it would work.
Just shows how much they know about these old trucks.
1951 GMC 100
Go back and read my post, I added additional info for you to consider......its' worth a phone call to LMC...
Best wishes
Ron - - Dusty53
1954 Chevy 3604
I bought the Champion radiator for my ‘50 Chevy and the bottom outlet was a different diameter, requiring me to go with a flexible universal fit lower radiator hose, which I didn’t like. Also, when it was bolted to the radiator support, it had less clearance than the stock radiator. I ended up cutting the flanges off of it and re-welding them on with the bottom of the radiator angled a little forward for fan/belt clearance- it was a PITA. The top inlet fitting diameter was also slightly too big, requiring me to stretch the hose a little… that cheap radiator saved me a bunch of money, though.
I cannot see why the stock unit is now nearly $600…. I just couldn’t bring myself to fork that much over for a radiator. Unless merchants are charging 100% markup now?
~ Dave
B Online: Content
"The V8 conversion only" clause probably works because the V8 engine is shorter front to back.
They aren't cheap, but searching for "CC46167 radiator" finds a part that is supposedly GMC specific. Cold Case (the manufacturer) has them as SKU GMT559A.
I have used the one from champion couple years ago. I'll admit it was for my 50 Chevy coupe but it fit like a glove and came with a nice radiator cap and bottom had cooler in case I ever wanted to put in an automatic. Reasonable price. Some of my frirnds have used them too.
I seem to remember champion is really made by U.S. Radiator but not comfirmed.
Any suggestions?
It should be 3125505. Its listed as Increased Cooling for your truck. An upgrade from the standard radiator. Core 2 in thick, 19 11/16 in wide.
Champion Radiator CC4754
Ebay
You are correct. Mine is so corroded I couldn't see the 3.
Interesting thing, the ebay one you said fits, when I select our truck, it says it doesn't fit.
Yet when I look it up on champion radiators it is that number.
I'm so confused!!!!
1951 GMC 100
Here is a link for the one that says it fits on ebay.
https://www.ebay.com/itm/1859291828...r=&widget_ver=artemis&media=COPY
1951 GMC 100
This is the same radiator you listed earlier. OE/OEM Part Number. CC4854
Your first one. OE/OEM Part Number. CC4854
CC4854
Click on the Ebay link in my post. It will take you to the radiator.
You do not enter the truck model, just scroll down to Compatibility, it lists six trucks 50-54 GMC only. It also gives all the measurements so you can check your radiator.
That is for a v8. We are using the original straight 6.
1951 GMC 100
Ebay
R&S, As jimgmc mentioned in his recent reply quoted above, suggest you look at his indicated GMC specific 6 cylinder radiator that goes by Part# CC4754. One number different than your linked CC4854 and different application list in the ebay ad.
Hopefully that may solve the confusion??? No worries, we are here to help! smile
BTW - If you want it to look more like the original, many folks just spray paint black. For more particulars on doing that you might want to Search the Site for previous conversations on painting radiators. wink
~ Dan
1951 Chevy 3 window 3100
Hey, looks like jimgmc and Gdads51 have a good recommendation and its a good price too. Go for it!
Ron - - Dusty53
1954 Chevy 3604
I think I found one that should fit.
https://www.ebay.com/itm/155990252023
1951 GMC 100
B Online: Content
Says it fits Chevys as well. I'd be skeptical.
Yes I have a re-cored 1949 GMC rad. Never used since re-cored as I found out it is a GMC and I need a Chev. I see you reside not too far from me as I am in Chilliwack BC. Contact me at [email protected]
Well darn. I ordered one and hopefully it fits..
I'm glad someone is close and can use that one.
1951 GMC 100
Well I will post today and see what happens
