4 members (Shaffer's1950, Oswald, JJs55210, 1 invisible), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1533460 01/19/2024 11:25 PM
1 Offline
On a early 1955 3100
My junction box is attached with a push on type clip, where can I get them?
The new boxes have nothing.
Thanks in advance for your help.
Pedals 3
Paddles 0
Mr G's Fasteners
Mr. G's Enterprises Automotive fasteners, of all types
5613 Elliot Reeder Road
Fort Worth, Texas 76117-6013
817-831-3501 or 817-838-3131
https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
I installed my new junction block with 7/16" bolts. All the stuff in black tape with the snap on connectors has been removed.
Otto, I think you meant 5/16" bolts, which have a 1/2" hex head. 1/4" bolts or even #10 screws would be plenty to hold them in place.
Another possible source for original style clips is Restoration Specialties. They have a ton of different style similar clips. LINK
Or you could use the plastic "Christmas tree" style push on fasteners. Or split rivets if you want to stay with steel.
Yes, you're right. 5/16"
Riding in the Passing Lane
If you mean a bolt with a 7/16 hex head it will be a 1/4 in bolt.
George
1972 Chevy c10 Cheyenne Super
I don't know what I mean. Whatever bolts I had laying around that fit through the holes is what I used.
Otto: Looking at your picture, is the firewall pad the only thing keeping the terminals from shorting to the body?
Or are there spacers on the mounting bolts/pins to space it out?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Yes, there are spacers.
AD Addict & Tinkerer
The standoffs are built into the junction block. I circled them in green in the picture.
The fasteners are 1/4 in bolts(7/16” head) about 1/2” long.
Junction block
Phil
Project Journals
Stovebolt Gallery Forum
Neat design. Simple but functional.
I need to replace my junction boxes this year. Nice reminder.
Craig
Sir Searchalot
Sir Searchalot
Anyway, back to the posters question. Now that we have discussed Otto's bolts.
The answer has been given by Phil and Otto. The terminal block has been improved.
The old block was held to the fender by push clips. The clips had a "step" or a "stop" built in to hold the board up and keep the "hot" screws from touching the fender.
The new block has a "stand off" at the screw hole on each end. (circled by Phil). It's just one of the wire terminal contacts flipped over. The standoff holds the phenolic board, and hot screws, up off the fender like the old one. New one is mounted with small bolts. Much better design. (check with Otto to see if he has any more bolts).
The best idea is to eliminate the board altogether and direct wire the lights.
CLICK
Insomniac
Insomniac
thumbs_up
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sure do. Free for the asking. Just pay shipping and handling. Money back if not fully delighted (shipping and handling not included).
