2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1532520 01/11/2024 3:03 AM
Sorry guys but I've danced around trying to figure out/verify my engine and I'm not having much luck. So here's my data if anyone has the investigative skills to decode:
1959 Chev 3100
inline six:
3764476 (found on block by starter motor)
3836848 (on top of head-drivers side)
F218J {machine flat area behind distributor) note: the number 1 could be the letter I
Thanks for the help. I'm assuming it's the original235cu engine but want to confirm
1959 Chev Napco 4x4 3100 w/235cu
This site indicates that your engine is the right year range to be original. Hard to nail down exactly.
Thank you sir,
So it appears to be 235cu, 58-62, by block and head.
F218J= Flint, Mich, Feb 18th, 3100-3800 models
Another sire from the one you posted:
http://devestechnet.com/Home/CastingNumbers
Thank you very much, nice for the confirmation,
Keith Hansen
Along with Kevin's information , using the the Engine number F218J breaks down as
F = Flint Michigan
218 = February 18
J = 3100 -3200-3300 Regular Production
So it is very possible you have the original engine.
Info taken from 1959 Chevrolet Truck Specifications Manual found at GM Heritage Site.
( edit - looks like we were both typing at the same time, I'll leave it....)
Ron - - Dusty53
1954 Chevy 3604
Thanks again guys
